95 auto trans
Old Mar 10, 2022 | 08:12 PM
BTW_DAKOTA's Avatar
BTW_DAKOTA
Default 95 auto trans
Is the trans electronically controlled by the ECM? I plan on doing a 360 carb swap and want to know if the trans runs separately or off the ECM.
Old Mar 10, 2022 | 08:15 PM
On the 95, the only thing the computer controls, is Torque converter clutch, and O/D. You can bypass the computer controls with a couple pressure switches. There is a write up around here somewhere for that.
Old Mar 10, 2022 | 08:17 PM
BTW_DAKOTA's Avatar
BTW_DAKOTA
Thank you! There’s so much I need to learn about this swap I plan on doing and I appreciate all the information you provide!
Old Mar 10, 2022 | 08:33 PM
bronze's Avatar
bronze
Originally Posted by BTW_DAKOTA;[url=tel:3539402
3539402[/url]]Thank you! There’s so much I need to learn about this swap I plan on doing and I appreciate all the information you provide!
I learn new stuff from these guys every day. Lack of humbleness is not a problem for me.
Old Mar 22, 2022 | 02:38 PM
Scaldeddog's Avatar
Scaldeddog
If no one has mentioned, don't forget the 360 is externally balanced, whereas the 3.9 and 5.2 are internally balanced. You'll need a 360 harmonic balancer and torque convertor. You can keep the 3.9 convertor if you can find a weighted flex plate.
And it has to be a Magnum set-up with a Magnum engine or an LA set-up with an LA engine. They are different.
