94 Dodge Dakota 5.2 V8 Fuse Box Wiring
Hello, I have a 1994 Dodge Dakota V8. I have 3 wires that was cut by the previous owner coming out of the engine fuse box. Is anyone able to tell what these are for. I am trying not to open the box because I do not have much experience on this issue. All 3 wires seems to be soldar together. I attached an image below. Thanks for your help!
That box opens pretty easily. Just a panel of relays and fuses under the cover. A diagram showing you what each one is for. As for those three wires, I do not know what they are for but I know there is a common problem (that I never experienced) with these Dakotas that is affectionately called the "Splice"...a wiring problem under that relay/fuse box. It's possible the previous owner ran into that problem or did some kind of modification that I cannot figure out from your photo. I'm confident someone will come along and be able to help you sort this out better than I.
thanks for the reply. I might just try removing it and see how it goes. As for the splice. Oh man. That caused me some big bucks before I finally found that splice. Looks like the previous owner gave up trying to figure out why it wasn’t starting or shutting down. I had to clean the wires and well for now things are running okay.
