Door glass installation
Old May 4, 2022 | 08:34 PM
Bdwhit's Avatar
Bdwhit
Default Door glass installation
I'm having trouble getting the arm in the track what's easy way
Old May 5, 2022 | 08:13 AM
onemore94dak's Avatar
onemore94dak
What truck what year? What arm?
If its a 1st gen dakota you should be able to see what you are working with. If it is a manual crank there are 3 bolts that hold it to the door. Anyway I ended up doing the glass run in this thread and wrote about what I did. I did not remove the glass from the door but it was all the way out of the track. https://dodgeforum.com/forum/1st-gen...ndow-trim.html
Old May 5, 2022 | 11:59 AM
Bdwhit's Avatar
Bdwhit
that will do it thanks . I was trying to not remove the crank
