Alternator not charging
Old Jul 3, 2022 | 12:33 AM
Chetti2's Avatar
Chetti2
Default Alternator not charging
Okay so I have a 92 Dodge Dakota 5.2 l V8 it has a brand new starter brand new battery brand new alternator the alternator is not charging the battery any ideas that this could be I replace the computer approximately a year and a half ago maybe less all my sensors are new new ground wires and plug wires like everything is basically rebuilt and this is my problem anybody please please help
Old Jul 3, 2022 | 09:20 AM
93 ragtop's Avatar
93 ragtop
If it was me, I would pull the alternator off and have it tested. Assuming it is good, double check your wiring and if there are any fusible links.... Then it is probably the regulator inside the computer.
Again, if it was me, I would try mounting an external regulator and wiring it up. I have seen links out there explaining how to do this.
Edit to add this youtube video I found.
https://www.bing.com/videos/search?q...tail&FORM=VIRE
Old Jul 3, 2022 | 10:36 AM
Chetti2's Avatar
Chetti2
I appreciate you for any assistance that you were able to give so appreciated I'm reading these sometimes and like I feel like okay that sounds like my problem and I get to and then it turns out to be like something weird so I appreciate any little input I can get
Old Jul 3, 2022 | 11:57 AM
hidden1's Avatar
hidden1
Mine was the diode in the alternator, but 01-Regulator is on the inside -, it tested great an then after driving ,no charge.The old trucks have regulator on the outside or you can put a better regulater on it..
Double check grounds an any fusable links too.
Old Jul 3, 2022 | 03:40 PM
bronze's Avatar
bronze
I just finished up a thread titled “Voltage Regulator”. Should be fairly close to the top of the list. Might be worth your time to go thru it since it seems I’m an expert on external voltage regulators these days albeit reluctantly.
Old Jul 20, 2022 | 12:59 AM
Princess_Kota's Avatar
Princess_Kota
Check for any rubbed wires from the alternator, though I'm sure you're meticulously checked everything to do with them. But honestly, it's entirely possible you got a crappy alternator. I've heard of people getting bad alternators from parts stores back to back to back. The fusible links are often a headache to deal with from what I've heard too. I'll be honest I don't know a whole lot but I'm doing my best. I don't have anybody irl to give me advice or bounce ideas off of so I know how frustrating it can be to deal with all this yourself. You can try looking up things that make alternators prematurely fail, I can't recall exactly what they are but I've heard of stuff like that.
