90 V6 no ignition for 5-10 minutes when cold outside
When below 75 degrees or so, there is no spark. Engine cranks, fuel pump comes on with ignition for a second, but no spark from coil wire. Leave ignition on for 3-5 minutes, engine starts and runs. Will run the rest of the day. Next morning, same issue. Connected a replacement distributor, no change. Computer/ECM?
Originally Posted by Ricgflys;[url=tel:3549739
3549739[/url]]When below 75 degrees or so, there is no spark. Engine cranks, fuel pump comes on with ignition for a second, but no spark from coil wire. Leave ignition on for 3-5 minutes, engine starts and runs. Will run the rest of the day. Next morning, same issue. Connected a replacement distributor, no change. Computer/ECM?
The following users liked this post:
tndakman (08-21-2022)
