Removing rear glass
Old Sep 8, 2022 | 12:59 PM
ol' grouch's Avatar
ol' grouch
Originally Posted by KlickMaker
Oh yeah I will be getting one with a sliding window, but I don't want to break anything if I can help it
Neat! I'll have to look into getting one of those
I'm well known for being chea..er..thrifty. I prefer to save a good part and can sell it to someone looking for it later. Usually cheaper than a new one. Both benefit from that. That said, I think I might pay a glass place to install the new window. Even though a I have a wallet that grunts when I spend a dollar, I'll pay and get it done quick and correctly.
Last edited by ol' grouch; Sep 8, 2022 at 06:35 PM. Reason: i kant spel wurth a durn
Old Sep 8, 2022 | 01:02 PM
bronze's Avatar
bronze
I'm well known for being chea..er..thrifty. I prefer to save a good part and can sell it to someone looking for it later. Usually cheaper than a new one. Both benefit from that. That said, I think I might pay a glass place to install the new window. Even though a I have a wallet the grunts when I spend a dollar, I'll pay and get it done quick and correctly.
Translated:
Old Sep 8, 2022 | 07:20 PM
KlickMaker's Avatar
KlickMaker
Originally Posted by onemore94dak
If you are going with a slider you will need a second pair of hands. I used the suction holder with a solid glass panel and it had to be in the middle. I don't think you can pull that hard on the slider windows without breaking them.
Thanks for the heads up, I still have to find a replacement window so I still have some time to decide what I want to do.
Originally Posted by bronze
Translated:
Old Sep 9, 2022 | 09:37 AM
Moparite's Avatar
Moparite
I have
these these
they really help when removing/installing glass with the rubber seals. They also help with plastic dash parts that you don't want to mar up with a screwdriver.
Old Sep 9, 2022 | 10:04 AM
ol' grouch's Avatar
ol' grouch
Originally Posted by Moparite
I have these they really help when removing/installing glass with the rubber seals. They also help with plastic dash parts that you don't want to mar up with a screwdriver.
The link didn't work. I have a set of plastic crow bars for interior body panels that does a decent job. I also have several suction cups from Harbor /freight that do a good job of holding glass. I use them to hold the glass up when I replace a window regulator.
Old Oct 13, 2022 | 01:12 PM
Greener70's Avatar
Greener70
Default A
[QUOTE=glenlloyd;3550260]I thought the 96 back glass was glued in? If you have the big rubber seal there's really nothing to taking it out, but if you have the glued in window you'll have to cut it out.
Also, there's apparently some difference between regular cab and club cab...so where ever you get the replacement make sure it's correct.
Steve any suggestions on what glue to use for a 05 dakota rear window,,its glued in and i need to replace
