MAP and TPS sensor
Old Nov 14, 2022 | 10:53 AM
Kafka45's Avatar
Kafka45
Default MAP and TPS sensor
I've got a 89 LE 2wd 5spd 141000k. What BRAND of MAP and TPS sensors are the most reliable? Finding these OEM is pretty much impossible.
thanks.......
Old Nov 14, 2022 | 11:06 AM
bronze's Avatar
bronze
thanks.......
That is always a good question and one without a great answer. Indeed, if I could find OEM I would. But as you say that may not be an option. In lieu of that, I try to get some clues from RockAuto. They'll have a ranking similar to "Good-Better-Best". Is that always reliable? No. But it's better than nothing. They'll also attach a heart symbol on the most popular brands. That gives you an idea of what others have purchased and you can draw some positive conclusions from that as well. I've always done well with NTK products (for example they are the OEM oxygen sensor on the Dakotas). Unfortunately, you're going to have to guess to an extent. Use your best judgement...stick with the familiar brands.
