My manual steering rack is practically flopping around on the passenger side
Old Nov 15, 2022 | 12:57 PM
WhiskeyHammer's Avatar
WhiskeyHammer
Default My manual steering rack is practically flopping around on the passenger side
Hello again!
My 89 Dakota manual steering rack has a lot of play on the passenger side. Take a look:
https://giphy.com/gifs/ftmZBoY8Dn2t5xgM1r
Up, down, left, right. All the slop.
I havent worked with steering systems much, but this looks like a bearing failure to me. I have the shop manual and some parts diagrams but I can't seem to find anything that shows a bearings here.
1) Is this normal? I'm assuming not.
2) Anyone familiar with the fix for this one?
P.S. I know I owe some responses to other threads. It's my busy season at work and this truck has had a loooooot of problems that I've been fixing. I'll get to those threads as soon as I have some spare moments to take pictures and format proper responses.
Old Nov 15, 2022 | 03:40 PM
Nope, not normal. The fix is to replace the rack.
Old Nov 15, 2022 | 09:16 PM
bronze's Avatar
bronze
Yeah, pretty clear it’s time for a new rack. No idea the availabilty of it. Could be a boneyard special if all else fails.
Old Nov 16, 2022 | 12:30 PM
WhiskeyHammer
Well... that sucks.
Can't find a remanufactured unit online. The salvage yards near me don't seem to have a match either.
I drove it from Charleston to Jacksonville (FL) and didn't notice any problems with the steering on the highway. It's a pain in the *** to crank the steering wheel sharply at low speeds but it was for sure doable. I think I'll cobble together a bushing to tighten it up for now. Worst case scenario my passenger side wheel looses active control - I'll still have the driver's side and friction will almost certainly force the passenger side wheel to reluctantly follow whatever line I'm driving. So reduced control with a higher input force on the steering wheel. Having said that worst case scenario, it doesn't seem likely. I can't imagine the kind of force it would take to snap a steering rack inside the guide, especially if the slop is take up by a bushing. I mostly use the truck for cruising the barrier islands on weekends so it's not like I'm catching pot holes at 80 mph or climbing rocks with it.
Old Nov 16, 2022 | 02:37 PM
onemore94dak's Avatar
onemore94dak
Rock Auto has a reman unit. Not cheap $233+ They also have parts for the rack. If its just the bearing or bushing you might be able to fix it ?????
https://www.rockauto.com/en/catalog/...nd+pinion,7388
Old Nov 16, 2022 | 06:23 PM
If one side is that bad, I bet the rest of the parts aren't much better. I think replacement, even though it ain't cheap, would be the best route to go.
Old Nov 16, 2022 | 08:45 PM
bronze's Avatar
bronze
Originally Posted by HeyYou;[url=tel:3555229
3555229[/url]]If one side is that bad, I bet the rest of the parts aren't much better. I think replacement, even though it ain't cheap, would be the best route to go.
Agree. That rack looked shot beyond hope. It’s like having a bum foot or ankle. Before you know it, your knees and back go lame too. Ask me how I know. I’m impressed 94 found that rack. He’s pretty good at hunting down parts.
