Help me please
Old Nov 16, 2022 | 04:07 PM
Jmhayes780's Avatar
Jmhayes780
Default Help me please
I have a few weird things going on with my 4x4 Dakota 1995
1. Whining at 50+mph that does not change with acceleration
2. lack of power when moving from a stopped position kinda feels like your in 3rd on a manual transmission trying to start from a complete stop if that makes sense
3. low transmission fluid and high rpm when shifting. I added trans repair fluid and now it seems to be normal.
any ideas would be greatly appreciated I just paid for new oil IAC etc so not looking to drop a ton of extra cash into this
Old Nov 16, 2022 | 06:26 PM
1. Bearing or rear gears going out.
2. Might be related to 1. Might not..... Think I would spin things by hand, see what ya got. Also, what engine ya have in there?
Old Nov 16, 2022 | 07:14 PM
Jmhayes780's Avatar
Jmhayes780
3.9 4x4
Old Nov 16, 2022 | 07:42 PM
May not hurt to check down in the intake anyway, see if you see oil pooling in there.
Old Nov 16, 2022 | 08:09 PM
Jmhayes780's Avatar
Jmhayes780
Originally Posted by Jmhayes780
3.9 4x4
im kinda thinking this may be a tranny issue is anyone else feel that way?
Old Nov 17, 2022 | 05:58 PM
The problem you run into there is, you have the 46RH trans.... so, the first three gears are purely hydraulically controlled. If they ain't workin' right, high probability that it's rebuild time...
Can you pull it down into first gear manually??
Old Nov 17, 2022 | 06:34 PM
Jmhayes780's Avatar
Jmhayes780
ya it will go into 1 and 2 manually. But nothing when I put it in drive. It just status in 2
Old Nov 17, 2022 | 06:55 PM
Whens the last time you did a fluid/filter change? Likely a band adjustment wouldn't hurt either.
Old Nov 17, 2022 | 06:59 PM
Jmhayes780's Avatar
Jmhayes780
I bought it a week ago so I have no idea
Old Nov 17, 2022 | 09:38 PM
Assume it hasn't been done for a while then.
Even if it has, it sure won't hurt.
