Kegger intake for a 5.2 Magnum
Old Jan 10, 2023 | 05:39 PM
karambos's Avatar
karambos
Default Kegger intake for a 5.2 Magnum
I have purchased the Hughes intake plenum plate and the kegger intake volume reducing plates from UTAwesome. I have a 1993 Dodge Dakota with a 5.2 Magnum (automatic). Its my daily driver and I want as little downtime as possible so my plan is to find another kegger intake and modify that then simply swap it.
But I am unsure as to which vehicles have a suitable kegger replacement. For example, there's a 1994 Dakota at the local scrapyard with a 5.2 engine. Would that intake be the same as mine?
Also, what kind of intake did the Dodge Ram truck have around that time? I know they came with a 5.9 but was the intake the same?
I know the following came with a 318 but I am not sure if the intake is the same as mine:
1992-2000 Dodge Dakota
1992-2001 Dodge Ram
1998-2000 Dodge Durango
1992-1993 Dodge Ramcharger
1992-2003 Dodge Ram Van
1993-1998 Jeep Grand Cherokee
Any help appreciated
Old Jan 10, 2023 | 07:28 PM
dodgetruck2's Avatar
dodgetruck2
Far as I know as long as its fuel injected magnum the intake will work, I think you need to stay 95 and older or you'll have to add a second port for the second coolant temp sensor. Might be issues for the EGR ports I'm not sure what year that stop but probably some overlap in used up parts with block off plates, probably 93-94 for EGR ports, unless you're planning on deleting EGR anyway
Old Jan 11, 2023 | 09:33 AM
EGR went away in 96.
