oil seal on crankshaft sensor
Old May 29, 2023 | 02:15 PM
tjohn's Avatar
tjohn
Default oil seal on crankshaft sensor
Hi Guys,
I hope somebody help me. I'm replacing the crankcase position sensor on a 1995 dodge dakota 3.9 manual. the oil seal has deteriorated so bad its in 4 pcs. Could somebody suggest where I can buy a new one. The old one was made of rubber and oval shaped to the fit the crankcase position sensor, and a sealing lip on to fit the opening in the rear on of head on engine.
TJohn
Old May 29, 2023 | 04:01 PM
It's just a dust seal. No oil in there. It probably serves as a vibration damper too though.... If the dealer can't get ya one, search on the part number
Old May 29, 2023 | 07:12 PM
tjohn's Avatar
tjohn
Just a dust seal? It was covered in oil, and the CMK was too. From parts mgr it was alright to be oily.
What is the part number?
Old May 29, 2023 | 08:05 PM
There shouldn't be any oil down there. You have a leak somewhere.
I couldn't find the part number. Can't find a diagram that even shows it.
Old May 29, 2023 | 10:54 PM
bronze's Avatar
bronze
Probably a leaky valve cover gasket.
Old May 30, 2023 | 07:40 AM
Or the oil pressure sending unit.
Old May 30, 2023 | 10:32 AM
tjohn's Avatar
tjohn
Thanks Guys,
The crankcase sensor was covered in oil, was probably vaule cover gasket leaking.
I cleaned the oil off and when i get a new seal put it back together and see if it runs.
Wish me luck !!
Old May 30, 2023 | 02:38 PM
Good Luck.
Old May 30, 2023 | 09:11 PM
AtomicDog's Avatar
AtomicDog
The part number is 52117709, but good luck finding one new. It's been discontinued for quite some time. Here is another thread that talks about it here - https://dodgeforum.com/forum/2nd-gen...r-grommet.html
