Help!
Old Aug 4, 2023 | 11:56 PM
Alindallastx's Avatar
Alindallastx
Default Help!
I am working on the pcm in my dakota due to electrical issues with map and idle air control valve
The bolt that holds the wiring harness plugged into the pcm just turns, i cant get the bolt out
Id appreciate any help you can give me.
Old Aug 5, 2023 | 08:43 AM
bronze's Avatar
bronze
This is a fairly common problem. TBH, I don't know what others have done to remedy it but be patient someone here will know.
Old Aug 5, 2023 | 09:00 AM
onemore94dak's Avatar
onemore94dak
This is what I did
https://dodgeforum.com/forum/1st-gen...olt-spins.html
Old Aug 5, 2023 | 02:16 PM
Alindallastx
Default Slipping bolt
Thanks for your help , I did drill off the head of bolt to get access to the unit.
