fuelhose/connections to fuel pump 1989 3.9Ll
Old Nov 10, 2023 | 01:09 PM
mlally's Avatar
mlally
Exclamation fuelhose/connections to fuel pump 1989 3.9Ll
I have access to the fuel pump after tilting truckbed,
The issue, is how do I disconnect the 3 lines/connections at the top, they are black and look like plugs
It also has a metal band/clamp, not a plastic lockring attaching pump to tank
Im assuming this is the original pump and doesn't look like a typical fuel module with easily removed connections
ns
Any suggestions would help, Thank you!
Old Nov 10, 2023 | 07:25 PM
onemore94dak's Avatar
onemore94dak
I found this post https://dodgeforum.com/forum/1st-gen...placement.html
Old Nov 11, 2023 | 03:04 PM
mlally's Avatar
mlally
Default thanks!!
Originally Posted by onemore94dak
appreciate it
Old Nov 11, 2023 | 05:26 PM
onemore94dak
Originally Posted by mlally
appreciate it
I hope it helps you solve the problem.
