Taillight issue
Old Dec 13, 2024 | 10:12 AM
Tstod's Avatar
Tstod
Lightbulb Taillight issue
My tail light is out just got my 95 ext cab like 1 month ago and my tail light is going out again and agin I have replaced the light and put a new one in 1 time and if I take out the housing and put it pack in it works assuming it’s a loose wire or something but a, unsure as this is my first car
Old Dec 13, 2024 | 11:20 AM
Welcome to DF! Everyone has to start somewhere.
There should be a ground wire running to the body somewhere right in the vicinity of the housing... check that first. If that doesn't help, does your truck have the factory trailer harness? If so, those were notorious for being crappy connections where the trailer harness hits the main rear harness.
Old Dec 13, 2024 | 03:16 PM
Tstod's Avatar
Tstod
Thumbs up
Alright I will check this weekend if it doesn’t work I will get back to here I do know it has a trailer light
Old Dec 17, 2024 | 09:44 AM
Tstod's Avatar
Tstod
So I was able to check my blinker and brake work and sometimes when I remove the housing it will work again and keep working for a few miles than stop again he it’s just my drivers rear
Old Dec 17, 2024 | 10:06 AM
onemore94dak's Avatar
onemore94dak
Did you find the grounds? I know there is one from the harness on the rear license plate lights on my 94.
Gotta be a bad connection somewhere... or a bad ground.
Old Dec 17, 2024 | 10:08 AM
Tstod's Avatar
Tstod
There is a ground that goes and bolts just to the frame and I haven’t traced it yet but I believe that’s the ground and it’s fine but the blinker runs off the same ground I believe so it shouldn’t be the ground
Old Dec 17, 2024 | 10:09 AM
Tstod's Avatar
Tstod
How big of a pain would that be to trace and fix or should I just bring it somewhere
Old Dec 17, 2024 | 12:28 PM
Might have a look at the connector itself then. See what the contacts look like. (loose ones might be problematic...) I have also seen bulbs with a broken filament, that if you tilt it just right, the filament makes contact again, and works. At least, for a little while.
Old Dec 19, 2024 | 09:50 AM
Tstod's Avatar
Tstod
so I tested it last night I am not getting power to the lights I do believe it to be a switch but there isn’t a power source for each filament that could be loose correct
