91 dakota 318 2wd
Old Apr 24, 2025 | 03:11 PM
Cody89's Avatar
Cody89
Default 91 dakota 318 2wd
Got a 51 ford f1 with all the parts from 91 dodge dakota 318 2wd push button o/d and my transmission started grinding when I put it in reverse then driving in first gear and it's locking up sometimes, I can put it in neutral when it does it then back in gear and most time that helps it, but what trans does it have incase I need one and what other years or vehicles have the same one ty
Old Apr 24, 2025 | 03:49 PM
Could be a number of different ones. Should be a part number on one of the pan rails that will tell ya for sure.
Old Apr 24, 2025 | 03:53 PM
Cody89's Avatar
Cody89
Default Number on trans
8 pk5211832421633337
Old Apr 24, 2025 | 03:56 PM
Comes back as a 46RH. Drop the pan, see what you find in there. My guess is..... crunchies....... likely rebuild time.
Old Apr 24, 2025 | 04:10 PM
Cody89's Avatar
Cody89
Default Thanks
Jus my luck lol I'll let you know what I find when I drop the pan, thanks for your help
Old Apr 24, 2025 | 04:34 PM
The bearer of bad new should always keep one foot in the stirrup.......
Fortunately, I'm outta range.
