What should i do.
Old Jun 5, 2025 | 05:29 PM
Ryan1996dd2w3.9's Avatar
Ryan1996dd2w3.9
Default What should i do.
After driving 3000 mile and getting back home my 1996 Dodge Dakota started to act funny started dying at intersections and then next day started up went to work went to go start vehicle again no start I've replaced ignition coil rotor camshaft and crankshaft sensors to no avail as well as the lead for the ignition coil and the ignition coil vehicle still will not start is there a special way of putting in a crankshaft position sensor it will read as of now if I loosen the crankshaft position sensor and wiggle it I can make my relays go off my fuse box not too sure what to do next
Old Sep 7, 2025 | 10:08 AM
garymunson's Avatar
garymunson
I'm currently trying to find another PCM for mine. The ASD and Fuel Pump relay would chatter and not pick up on occasion. I finally chased the issue to the PCM itself. You may want to start out by check all the wiring ground points under the hood. Bad grounds will affect the operation of those two relays and temperature changes seems to make it worse.
