oil pressur e?
the guage shows that it is always low ...
like its just inside the little area that i guess should be good
the oil is exactly where it should be ..
what would cause the low oil pressure ?
Thanks in advance
Thanks in advance
The sending unit has been known to fail over time. However, most likely the pickup screen is partially blocked. Happens a lot on high mileage magnum engines. Sludge buildup will block the pickup, resulting in decreased oil pressure. Drop the pan and clean it out. Fair amount of work on the 4x4 though due to clearance. I think you may have to remove the engine to do it. The 2wd can just be raised an inch or so to get it off.
