Wheel swap questoin?
Old Jan 17, 2006 | 11:11 AM
94Dakota318's Avatar
94Dakota318
Default Wheel swap questoin?
I have a 94 Dodge Dakota.. i was wondering what rims fit on this truck with out changing the offset????
Any one know ..
Thanx
Old Jan 18, 2006 | 12:22 AM
360DakotaPwr's Avatar
360DakotaPwr
Default RE: Wheel swap questoin?
Any stock wheel from early 80's to 96 Dakotas will fit.
The late model closed spoke rim (15x7) COULD POSSIBLY fit with some spacing and longer studs.
The open spoke late model wheels will not fit (15x8) at least on a 2WD.
RT wheels will fit with either thick wheels spacers and longer studs. Or Grind the control arm. run an 8th in. spacer. Hammer down the dust cap and call it a day. You can cut the centers out of old brake drums to make your spacers for the 17 in. RT wheels.
Old Jan 18, 2006 | 01:09 PM
Ruggels's Avatar
Ruggels
i wouldnt mind some 2nd gen dakota rims actually nice sporty one
should fit then i have a 92 4x4 so all ill need is longer studs anda wheel spacer then ?
235 75 15 little small for me
whats the 2nd gen tires sizes anyways i want something to raise the truck a little and look more sturdy beefy etc
Old Jan 18, 2006 | 09:44 PM
360DakotaPwr
2nd Gen came stock with 31in. tires. The open spoke 15x8 will go on a 4x4. There is a guy on this forum that has them on his. Contact JDakota92.
Old Jan 19, 2006 | 03:29 AM
Ruggels's Avatar
Ruggels
what about 17x9 or the 16x8 just curious ? would they fit i pm'd the guy you said but im curious about these other rims thanks
Old Jan 19, 2006 | 10:13 PM
360DakotaPwr
The RT wheels will fit with modifications as I stated above.
I have not tried the the 16's personally, because judging how the 17's fit on my truck. The lip on a 16in. wheel will be right next to the upper control arm. It probably would fit with some grinding and spacing, but like I said. The 17's on my truck ride just above the control arm, so it could be a problem.
Old Jan 20, 2006 | 03:23 AM
Ruggels's Avatar
Ruggels
ok so im not gonna pretend to know anything about tires lol
my rims are the stock ones 15x7 or 8 not sure they not the ugly ones they pretty nice ..
have 235/75/15 on them now .. i was gonna put 255 is that to big ?
cause im not sure what size 31" tires are if they have an actual size .. the 15" rim you said open spoke will directly fit on my truck ?
sorry im a newb and a lil slow on tires lol
like what size is the tire tat is 31" or they dont have a size like 235 255 etc ?
<-- are these the 15" 15x8 that you said would directly fit my truck ~
Kirk
Old Jan 21, 2006 | 02:23 AM
360DakotaPwr
The wheel in the picture will fit your truck. It is a 15x8 and categorized as an open spoke configuration. I wont say they will directly fit but they will go on there. You need to talk to JDakota92 about that.
A 31in. tire can equate to anything from a 245 to a 265, it just depends on the other number. 255 should fit a 4x4, but you need to hold it up there and see.
Old Jan 22, 2006 | 02:20 AM
JDakota92's Avatar
JDakota92
Thanks for the reference 360DakotaPwr. 31" tires can rub on a '87 - '96 Dakota. I tried fitting them and I wasn't satisfied by the close clearance. I have 30x9.5/R15's and they fit perfectly. The next generation of Dakota's have bigger wheel wells which allowed for bigger tires. 31's came stock on 4x4 Dakota's and Durango's.
For anyone else having questions about fitting the 15x8 wheels on a '87-'96 Dakota, there are two ways to do this. One, have some custom spacers made (1/4" for the front is needed to clear the brake caliper line bolt). An old brake drum or even an old wheel will do fine. I happen to have a set that were custom made out of my old 15x6 wheels. I went a different route as I couldn't find longer studs with more threads. I instead ground down that brake line bolt just a little bit and then to go with it, had the inner lip of the wheels machined to clear the brakes. I only cut out ~1/16" or less and in about an inch. It's difficult to explain. The integrity of the wheel was not compromised. They've been on for 2.5 years and have put on about 25k miles with no problems. I've even gone off road with them and again, no problems. I would have prefered to go with the first option, but the spacers are illegal where I am and I couldn't find the longer studs to support them.
Old Jan 23, 2006 | 03:57 AM
360DakotaPwr
No Problem Man.
I agree with him, find longer wheel studs and use spacers. Racing catalogues should sell them. Find out the size and thread dimensions and you shouldnt have any problems ordering them. Its a pretty common size.
