Coolant leak on driver side somewhere
Old Jan 18, 2006 | 02:00 AM
RWFrazier's Avatar
RWFrazier
Default Coolant leak on driver side somewhere
Hello there,
I have a question that maybe one of you could help me with, I have a 94 Dakota 4x4 and there is a coolant leak on the left (driver) side of the motor somewhere, I can't really tell where it is coming from it looks like it is under the AC unit. I have replaced the waterpump and the little bypass hose hoping that was it but I still have a leak. Anyone have any ideas?
Old Jan 18, 2006 | 09:39 PM
360DakotaPwr's Avatar
360DakotaPwr
Default RE: Coolant leak on driver side somewhere
You may have the style water pump that has a black steel pipe going in the left side of it for a heater hose. There is an O-Ring in there. If its not seated right, it will leak. Check that and you may want to use a little silcone sealant too.
Old Jan 19, 2006 | 12:55 PM
RWFrazier's Avatar
RWFrazier
Thanks for the reply, I have actually replaced it and sealed it up and still I just can't tell where it is coming from, almost looks like it may be on the block somewhere. A freeze plug maybe? I wish I had a diagram of the entire cooling system.
Old Mar 20, 2006 | 03:42 PM
RWFrazier's Avatar
RWFrazier
UPDATE!!
I have been to the mountain and I have seen the promised land, and I have figured out why my 94 Dakota was leaking coolant. The timing belt cover needed to be replaced.
Old Mar 22, 2006 | 06:39 AM
kent_08's Avatar
kent_08
my buddy had same problem with his timing belt cover, he had to replace it with a new one.
anyways, just look for a reliable dealer that won't charge you with lots of bucks.
