raise the front end
Old Mar 17, 2006 | 02:53 PM
Ruggels's Avatar
Ruggels
Default raise the front end
ok i think i saw somewhere before onhere it said something on how to lvl off the front end of the truck ?
92 dakota 4x4 seems more noticeable now sinc ei put the 31" tires on so i was wondering how i could make it look a little better ?
torsion bars ?
hard or just move them or something
Thanks for reading
Old Mar 19, 2006 | 02:24 AM
Ruggels's Avatar
Ruggels
Default RE: raise the front end
anyone im sure out of the 20000 on the site someone knows how to lvl the front end off :P
Old Mar 21, 2006 | 02:25 AM
makericerscry's Avatar
makericerscry
at the back of the torsion bars there is a big bolt (one for each) that you tighten to lift it. just crawl under there and you'll see what i'm talking about. when you do this you'll probably have to get an alignment done and you should get 1.5 to 2 in of lift. of course you could get lucky like i did (the alignment was off in the opposite way so it fixed it and i got about 4 in out of it). my suggestion is to jack up the front, tighten the bolts all the way then let the car down, roll it about 20 ft back then forward and lower it back down to were you want it. if you tighten it alot like i did the it will be a much stiffer ride and if your back shocks are dead it will handle terrible on high speed turns, so be prepared to replace those.
Old Mar 22, 2006 | 01:25 PM
Ruggels's Avatar
Ruggels
thanks for the advice i will do asap .
i just blew the shocks on my pass side lol went off roading and i slammed through an icy patch into a big rut so now im getting shocks all around costs money to have fun lol
