Exhaust header question
Old Feb 21, 2006 | 05:30 PM
mark.turner's Avatar
mark.turner
Default Exhaust header question
I'm looking to replace the exhaust manifolds on my 94 318 dakota.
Which would be better: performance-wise?
a set of aftermarket shorty headers:
or a set of 92 ex manifolds.
I'm replacing the Y pipe either way I go (plus exhaust), so that's not important.
I appreciate your help guys!!
Old Feb 23, 2006 | 02:56 AM
360DakotaPwr's Avatar
360DakotaPwr
Default RE: Exhaust header question
92 or 93 manifolds will flow a little better.
Doug Thorley made a set of headers for 92-95 I think that are tri Y setup. They are the best for the street. It comes with a Y pipe to bolt in the stock location. Problem is fonding them. So if you do let me know. Summit sells them for $500. Ouch, but they will perform better than some BS shorties you can find all over ebay.
Old Feb 23, 2006 | 12:59 PM
mark.turner
thanks..
I'll start looking for the DT Headers then.
Old Feb 26, 2006 | 12:07 PM
dak3.9's Avatar
dak3.9
Do you know where i can get a full exhaust for my 1990 dakota 3.9? And can i make it true dual?
Old Feb 26, 2006 | 09:19 PM
360DakotaPwr
To my knowledge. Nobody makes a kit for our trucks. If you buy mufflers and headers online (ebay) or whatever. You should be able to find someone to custom make it for under $300.
Old Feb 26, 2006 | 11:43 PM
dak3.9's Avatar
dak3.9
I always thought exhausts on ebay weren't that good, but i could be wrong.
Old Feb 27, 2006 | 02:33 AM
360DakotaPwr
I mean buying mufflers and tips or whatever you want. A flowmaster muffler off ebay is the same as from summit as long as the ebayer represents it correctly. You can buy mufflers and tips cheaper on ebay, take them to an exhaust shop and have it installed. This will help keep th eprice down. Do some shopping around and see where you can get it the cheapest.
Old Feb 27, 2006 | 11:12 AM
dak3.9's Avatar
dak3.9
Ok. I'll shop around.
