tires
Old Feb 23, 2006 | 11:31 AM
bionic4.0's Avatar
bionic4.0
Default tires
I have a 93 dokota v6 2wd ext cab conversion truck lowered 2 in from dixie customs i need some tire the tires that are on it are the wrong size they are 225/75/r15
i am wanting some hting a lil wider and shorter (mostly wider i want widest posible) waht size would you sujest me go with
Old Feb 24, 2006 | 03:44 PM
OneBadKota's Avatar
OneBadKota
Default RE: tires
I put 245/60/15's on mine. About the max you can do without rubbing. Also, I have them on a 7.5 deep wheel.
Old Feb 25, 2006 | 12:59 AM
bionic4.0's Avatar
bionic4.0
Default RE: tires
are they shorter and wider or what i want the wides i can go
Old Feb 25, 2006 | 01:27 PM
OneBadKota's Avatar
OneBadKota
Default RE: tires
Yeah, they have to be shorter the wider you go or it will rub. I have mine lowered 3 inches, so, it's the biggest I can go. I've attempted a 255/70 on the front, but they will rub horribly. The 245/60 is about 25MM wider and 20 shorter. The first number (245) is measured in MilliMeters I believe, measures the width. The second number (60) is the percentage of the first number, for the height. I can get pictures of mine if you need an idea of what it looks like.
Old Feb 25, 2006 | 01:49 PM
bionic4.0's Avatar
bionic4.0
Default RE: tires
please like i said im oly lower by 2 in the front and 1.5 in the rear i think is what i was told when i cold the company right now i have 225/75 front and 235/75 rear both on 15 inch rims i dont want it to have the tires pokin out the side and making it look funny just like it is sitting low on some wide tires
Old Feb 25, 2006 | 02:53 PM
OneBadKota's Avatar
OneBadKota
Default RE: tires
I tossed a couple pictures on a site. http://journals.aol.com/blahblahblahyoyo/OneBadKota/ Hope those work well enough for ya.
Old Feb 25, 2006 | 07:02 PM
bionic4.0's Avatar
bionic4.0
Default RE: tires
thanks that helps how do they handle and what not and what brand are they
Old Feb 25, 2006 | 08:20 PM
OneBadKota's Avatar
OneBadKota
Default RE: tires
Well, they handle pretty good. It's a Kelly Charger, I got it from Belle Tire. I think they're like a 55,000 mile tire and I got them for about 35 bucks each. I've had no problems..
Old Feb 26, 2006 | 12:23 AM
bionic4.0's Avatar
bionic4.0
Default RE: tires
can i get a front and rear shot
Old Feb 27, 2006 | 04:26 PM
OneBadKota's Avatar
OneBadKota
Default RE: tires
Tossed four more pictures up for you. Same link, same entry. Hope those work.
