Engine swap
Old Mar 4, 2006 | 02:56 AM
injmopar's Avatar
injmopar
Default RE: Engine swap
Also the 360 has a longer stroke which produces more torque.More power starting down in the bottom
Old Apr 7, 2006 | 08:11 AM
moparmanewulm's Avatar
moparmanewulm
i have a 93 4x4 with a 3.9 would i beable to get a 360 in with out haveing to change trans or relocating the transfter case and what not?
Old Apr 7, 2006 | 02:51 PM
OneBadKota's Avatar
OneBadKota
Shouldn't be a problem. I saw an 89 drop top done up with a 360 Magnum.
Old Apr 18, 2006 | 12:04 AM
BlackDak07's Avatar
BlackDak07
would the trans of an older dak bolt up to a newer 360??when i say newer i mean 98 and up
Old Jun 4, 2006 | 05:00 AM
martimus5's Avatar
martimus5
Can you use a 360 from let's say an 89 year model truck? Oh, and can you go carberated instead of fuel injected. Can a 360 from 92 or newer truck be carberated? What about the tranny, can I use the one from an 89 truck. The reason I ask, is because I have access to an 89 dodge as a donor truck. Any help, would be greatly appreciated.
Martin
Old Jul 4, 2006 | 05:27 PM
sheriandwill's Avatar
sheriandwill
I have a 93 dakota sport 4x4 with a 5.2 and a 93 dakota 4x4 donor truck. will I be able to use the same y-pipe with out having to change it when I do my swap? I am leaving the engine harness on the motor for the computer and transfering it all to the truck..
