temperature sender 1990 dakota
Old Mar 16, 2006 | 02:41 PM
gman1964's Avatar
gman1964
Default temperature sender 1990 dakota
I have a 1990 dodge dakota - v6. The dashboard temperature gage does not work. The engine is warming up fine but the needle does not move on the gage. I purchased a temperature sender for the truck. My question is that I know there are two senders/sensors. One goes to the computer and I found that one(it has a plug with a clip etc...) I'm looking for the single wirte sender .Where is the sender on the engine as you look at the truck from the front?
Old Mar 18, 2006 | 12:10 PM
harry_angel69's Avatar
harry_angel69
Default RE: temperature sender 1990 dakota
The temp sensor is on the left next to the thermostat. You will need to remove the altnator to get good access. Be careful because I broke one off last week. Mine did not seat all the way in, but is does not leak.
