Back Brakes
Old Mar 27, 2006 | 03:31 AM
bdodge_445's Avatar
bdodge_445
Default Back Brakes
My 92 Dakota 2wd does not have any back brakes at all. They are there, but they are not working lets put it that way. My brake light is on as well as my anti-lock brake light. I would rather fix the problem myself than bring it into a shop and if possible get rid of the antilock system all together. Any suggestions as to why my brakes aren't working would be appreciated. Thanks
Old Mar 27, 2006 | 04:03 AM
Dakota Brad's Avatar
Dakota Brad
Default RE: Back Brakes
unplug the ABS module then the abs light will go out and the e-break light will go out,
Old Mar 27, 2006 | 09:46 AM
oldmansdakota's Avatar
oldmansdakota
I had to replace both lines from the center of the rear axle out. Also replaced the rear wheel cyl's. This on a 1992 ex cab V8
Old Mar 27, 2006 | 05:18 PM
Dakota Brad
try adjusting them
Old Mar 28, 2006 | 12:28 PM
Sneezer's Avatar
Sneezer
Jack up the rear. Pull the access port on the back of the drum and you will see the star wheel adjuster. Use a flat blade screwdriver, or better yet a brake tool. Adjust them until they just start to drag. Mine was like that for a while, adjusted them properly and made a huge difference.
Also - pull the drum and check the condition of the wheel brake cylinder. Make sure there are no cracks, tears or leaks from the rubber boots. Replace as needed - they are cheap from Autozone.
If you rear brakes are way out of adjustment, they will trip the brake warning system due to excessive travel.
