spindle
Old Mar 31, 2006 | 02:39 AM
91V8dakota's Avatar
91V8dakota
Default spindle
Ok guys i need some help with the brakes. The threads in the bolt holes on the spindle that holds the calipers on are gone. They look to have rusted away. The bottom hole on the passenger side appears to have been re-tapped to a bigger size sometime in the past - but that was the bolt the was missing when I took it apart. I am not sure what kind of bolt was being run - those bolts are unique. The top hole on the passenger side is stripped. The bottom hole threads on the drivers side are rusted away. The guide bushing had been removed and a non-OEM bolt placed in the hole. The top hole was good though.Im not sure on how to repair this problem using the spindles that are already on it.If i cant repair it and have to go to a junkyard to get new spindles.Does anyone know if a spindle on another dodge would work here.thanks for any help.My truck is a 91 4x4 V8.
