rear brakes
Old Apr 16, 2006 | 03:18 AM
bdodge_445's Avatar
bdodge_445
Default rear brakes
my back brakes dont work at all on my 92 dakota 2wd and i am told it is a common problem. both my brake light and anti-lock brake lights are on. any suggestions on why my brake arn't working? also my e-brake doesnt work either.
Old Apr 17, 2006 | 02:28 PM
Sneezer's Avatar
Sneezer
Default RE: rear brakes
Have you adjusted the rears?
Jack up the rear and support on jackstands. Remove the access plug from the back of the drum. You will see a star wheel adjuster in there. Use a flat blade screwdriver, or pick up a brake tool kit from the parts store which has a curved tool that works much better. Spin the tire with the parking brake off. Keep rotating the adjuster until you just begin to hear/feel the shoes drag on the drum. Do the same thing to the other wheel. Once done it should be fine.
While you are at it, pull the drums to check the condition of the shoes and the brake wheel cylinder as well. Any cracks in the rubber boot or evidence of leakage and you should replace it. Cheap and easy to do.
