Intake and engine mounting question
Hey, I picked up a 318 out of an 88 ram, I was wondering what would be required for converting the intake on it (efi throttlebody) to carb'd. I know its relatively easy but I keep hearing defferent things.. such as the carb requires a mechanical fuel pump or I might be able to purchase a "fuel regulator" and keep my exisiting fuel pump. I was wondering if anybody could confirm what exactly is needed for the fuel pump for the carb'd engine (I'm new to car carbs but want to learn them a bit).
Also, since I want to put this engine in my 96 dakota I was wondering about the motor mounts. I know that the ram engine has "ear type" motor mounts which are different from the 3-bolt pad mounting found in dakotas. I was curious if anybody has done this with a ram engine and how exactly they put it in.
Thanks alot for any helpful information!
RE: Intake and engine mounting question
I did an LA swap 360(out of a 74 Ram) into my 3.9 FI. You will most likely need the Schumacher motor mounts (www.engine-swaps.com). As for going to carb, run a mechanical fuel pump and gut your old one so you don't have to fill the hole in the tank. FI runs about 48psi and you need to run about 6psi. So, you will be needing about 4 fuel regulators. You can pick up a mechanical pump out of a junkyard. It's a must to gut the old fuel pump and use bigger hose.. or else you will not get enough fuel through.
There's a bunch of crap in the fuel pump(filter, hose, etc) Just take out the insides and push I believe I used a 3/8s hose down, just up from the bottom. I ran the hose from the bottom of the tank to a little bit up the frame rail. Just for now, until I can do the whole system with new lines. Then, I cut the line up on the fire wall. Ran the 5/16s hose from there, to the pump and to the pump to the carb. I can get pictures if need be. (I put a filter on the fuel hose from pump, just off the carb.) While the tank is down, I would recommend checking the whole thing over for leaks since the plastics are notorious for it. Also, if you can, get new metal straps for it.
