90 Tachometer Problem
Old Sep 4, 2006 | 04:46 PM
kahanabob's Avatar
kahanabob
Default 90 Tachometer Problem
My tach just stays at 2500rpm when the engine is running. Took it out and cleaned the 3 pins connecting it no help. Where is the signal comming from that feeds the info to the tach? Is there like a sending unit? Is there any way to bench test the tach?
Thanks
Old Sep 4, 2006 | 07:16 PM
erock92kota's Avatar
erock92kota
Default RE: 90 Tachometer Problem
This is a good question. Mine has been stuck at 4 grand since the day I got it. Whether its on or off, the tach says 4 grand.
I am not sure about a sending unit or anything like that. My book contains no wiring diagram pertaining to the guages. I havent really had time to pull it apart and see what is going on with it. Aftermarket tachs have a lead that hooks up to the neg. side of the coil, a battery connection, a ground, and a wire to tie in the illumination with the interior lights.
I would imagine the factory tach would get its signal from the computer. This is just my guess, not hard data. I may be wrong on this, if so please correct me. But I would think that the computer would be able to tell the tach what to display since it knows via the crank sensor.
Hope this helps and I havent led you astray.
Old Sep 4, 2006 | 08:18 PM
dodgerules86's Avatar
dodgerules86
On my '96, the tachometer is controled, basically, by a "tachometer module" that is mounted right above all the gauges (if you pull out the instrument panel assemly, you can see it). I have no idea when they changed to this setup.
If you read the first paragraph, it says if your tach does not return to 0 after you turn the ignition to OFF, to check for battery voltage at the fused B+ cavity of the left instrument cluster connector (red connector, cavity H).
The frequency chart is as follows:
2000RPM (+/-140) 66.7Hz
5000RPM (+/-140) 166.7Hz
[IMG]local://upfiles/948/393AACDEDEB4449C805B0B588CC75813.jpg[/IMG]
[IMG]local://upfiles/948/BBB47F11558E4E18B3A9A0051ED6BA39.jpg[/IMG]
[IMG]local://upfiles/948/520D398E7AF642F18CBCEA87B20CC4DD.jpg[/IMG]
[IMG]local://upfiles/948/BC577B1409A6444B89220CA255599058.jpg[/IMG]
