anther beginer question
Old Sep 3, 2006 | 07:09 PM
89 dakota's Avatar
89 dakota
Default anther beginer question
I'm doing the rear brakes on my truck right now with much frustration[sm=bomb.gif] I finally have the shoes and the whole assembly back together and now my drum won't go on. I've tried the adjusting screw but that doesn't seem to be doing anything. I don't know what to do???? Also this morning when i was loosening the lugs I stripped one due to my wrench braking how can i get it off????
Old Sep 3, 2006 | 07:11 PM
89 dakota's Avatar
89 dakota
Default RE: anther beginer question
P.s I also noticed my fuel gauge doesn't work properly. How can i fix it?
Old Sep 3, 2006 | 07:20 PM
89 dakota's Avatar
89 dakota
i just checked out the faq section now i know what to do about the gauge.
Old Sep 3, 2006 | 10:37 PM
gb6491's Avatar
gb6491
Outside what you've already checked (proper assembly and adjuster screw fully closed), some things to check when putting the drum back on are:
Wheel cylinder relaxed
Parking brake off
Make sure you have the correct shoes as there are two size brake assemblies (9" and 10").
In regards to the lug; by stripped do you mean that you rounded the shoulder off the nut?
If that's the case, there are sockets designed for rounded nuts (I believe Sears carries them. Auto part stores sometimes sell them as Emergency Lug Nut Removers) or you could try a nut splitter.
If you stripped the threads on the lug, sometimes you can refresh the threads; if not, you'll have to press/drive that one out and replace with a new one (I think that will involve pulling the axle).
Regards,
Greg
Old Sep 3, 2006 | 11:02 PM
89 dakota's Avatar
89 dakota
how do you relax? the cylinder. Also how could i check to see if i have the right size shoes? I asked the guy for 9" loudn' clear.
Old Sep 3, 2006 | 11:22 PM
gb6491's Avatar
gb6491
Take the lid off the master cylinder, then try compressing both ends of the wheel cylinder (by hand or with a C clamp). Check the cylinder for damage as well.
You might be able to check the part number on line.
Regards,
Greg
Old Sep 4, 2006 | 12:15 AM
89 dakota's Avatar
89 dakota
opening the master cylinder fixed my problem, Thanx for the advice. I'd probably STILL be cursing out in my garage. I'm completly inept at mechanical things but i'm gonna learn damn it!
Old Sep 4, 2006 | 10:11 PM
gb6491's Avatar
gb6491
[sm=icon_cheers.gif]You are welcome; glad it helped some.
Regards,
Greg
