oil for manual transmission
Old Sep 14, 2006 | 07:47 PM
drc581's Avatar
drc581
Default oil for manual transmission
I recently purchased a 1994 Dodge Dakota 3.9 manual transmission. I would like to change the transmission oil but not sure of the wt. Called several dealers . one dealer told me ATF another said 80wt. Checked a Chilton manual. According to then use 10w30. Any help in this matter would be appreciated. drc581
Old Sep 14, 2006 | 08:25 PM
gb6491's Avatar
gb6491
Default RE: oil for manual transmission
The 89 factory service manual reads 2 quarts (US) SAE 10W-30 engine oil for the NP2500 Overdrive 5-speed.
Regards,
Greg
Old Sep 14, 2006 | 10:38 PM
dodgerules86's Avatar
dodgerules86
For the AX15, use 75W-90. You will need about 3.5 quarts.
For the NV3500, use Mopar Manual Transmission Lubricant, P/N 4761526. You will need about 2 quarts.
I must say, the service manual stresses that the Mopar Manual Transmission Lubricant must be used where specified. Usually, the service manual will say something like "Mopar something-or-another or equivalent" but this doesn't.
Old Sep 21, 2006 | 12:09 PM
drc581's Avatar
drc581
got 2qts 10w30 vavaline synthetic. changed the oil seems to be working fine.
thanks drc
