89 Dodge Dakota 3.9 Throttle Body Injection......
Old Oct 19, 2006 | 07:48 PM
Lisa45601's Avatar
Lisa45601
Default 89 Dodge Dakota 3.9 Throttle Body Injection......
On a 89 Dodge Dakota 3.9 Throttle body injection do they have a "Relay" Or a "fusilbe" Link or is it a problem area?
The fuel pump is good but it is not getting voltage to it.
Any help would be great.
Old Oct 19, 2006 | 09:21 PM
BOOMER_87's Avatar
BOOMER_87
Default RE: 89 Dodge Dakota 3.9 Throttle Body Injection......
it's a relay however I'm not exactly sure where it is
Old Oct 20, 2006 | 01:41 AM
dodgerules86's Avatar
dodgerules86
In the pre-1992 dakotas, there wasn't a fuel pump relay. The fuel pump just got its juice from the automatic shutdown (ASD) relay. How, you might ask, do you know if your aSD realy is good? Well, check to see if its getting spark, because the ignition coil is feed thru the ASD.
With that being said, I believe somewheres on the back, driver side of the frame (behind the rear axle I believe) there is a connector. The positive wire for the pump should be the dark green and black wire. The negative wire for the pump should be the gray wire.
Old Oct 20, 2006 | 02:02 PM
Lisa45601's Avatar
Lisa45601
Thank you both for all your help.
Old Oct 20, 2006 | 08:03 PM
dodgerules86
Hey, no problem! That's what we're here for!
Let us know what ya find, always nice for those that come later.
