PLZ NEED HELP FAST
i have a 93 dodge dakota 2wd w/ 3.9 v6 club cab w/ automatic tranny it was my uncles before he passed away and i had put some lucas oil in the tranny and now when i put it in reverse it engages and you can hear it engage and feel it but it wont move same with first gear but 2nd and drive and o/d it will move but it is very bogged down like im hauling a semi was needing to know if i need anew tranny or if a good flush and new filter and fluid would cure my sick truck please any help will be greatly apprciated
[IMG]local://upfiles/48463/55B56A19048C4DCEAC68A6E34C524B6D.jpg[/IMG]
Hey if it were my truck i would do a flush and fill....its very in-expensive to do so and would save you on buying a tranny...sometimes you have to watch putting new detergents into trannys...they tend to be very picky at times...if it hasn't a a flush and filter...i would definetly do that first. If you decide to do that, look in the bottom of the pan for a lot of metal shavings things like that....you will have very little...the other thing you can check is the color of the fluid...and the smell...if it has a burnt smell then you might need to do a rebuild...or if the fluid is a really dark brown or black...I hope i was able to send some little help....good luck man
thanks man i checked the fluid a few days ago when it first started acting up and it looks smells and tastes just fine so i am thinking that its just a clogged filter and maybe the pump is too but i was just needing some reassurance on what i thought ive been a mechanic for years but never done any tranny work except for changing them out LOL
