heater question
Old Nov 11, 2006 | 01:29 PM
spudsterier's Avatar
spudsterier
Default heater question
i was wondering if anyone could help me with a heater problem that i am having with my 1993 dakota sport....i would like to get it fixed before it starts getting too cold outside
anyways, the heat doesnt get vey hot at all.....the blower works, there is plenty of coolant, and the temp gauge reads normal.....but it just isnt very hot, however the faster you go the warmer the heat gets...a little anyways not alot
i am thinking it might be the heater core, but i dont know anything about anything but neons so i need some help with this one...
thanks
Old Nov 11, 2006 | 08:41 PM
dodgerules86's Avatar
dodgerules86
Default RE: heater question
You should back-flush the heater core. A regular garden hose and a connection fitting is all that you need.
You should also back-flush the block and radiator while your at it just to make sure everythings clean.
Old Nov 11, 2006 | 10:09 PM
spudsterier
thats what i heard, but i just thought i would check...
i just need some heat since i have to have the windows open almost all nite/day because of work....and its starting to get cold outside
