Steering is loose...
Old Nov 14, 2006 | 11:16 PM
gtup's Avatar
gtup
Default Steering is loose...
My steering wheel is VERY loose. Is there something i can tighten to make it normal again?
Old Nov 15, 2006 | 12:19 AM
dodgerules86's Avatar
dodgerules86
Default RE: Steering is loose...
Could be loose, worn or damaged: steering linkage, tie rod, steering column u-joints, steering column bearings; damaged or worn steering gear; or loose steering gear bolts.
I would definitly check your tie-rods and ball joints.
Old Nov 15, 2006 | 01:46 AM
injmopar's Avatar
injmopar
Look at the steering shaft under the hood and have someone move the wheel with in the loose travel. Do this with the engine off. The u-joint is a common problem. But if your lucky its just a tye rod end. You can test these the same way.
Old Nov 15, 2006 | 10:10 AM
gtup's Avatar
gtup
Cool... now when looking under the hood where can i locate these?
Old Nov 16, 2006 | 01:29 AM
dodgerules86
[IMG]local://upfiles/948/B068234FEDF24A9691591DB17872717E.jpg[/IMG]
There ya go!
Old Nov 16, 2006 | 03:18 AM
gtup's Avatar
gtup
ORIGINAL: dodgerules86
There ya go!
Cool thanks man!!
Old Nov 19, 2006 | 12:34 AM
reindeerman's Avatar
reindeerman
What year is your truck? Is it 2-wheel or 4-wheel drive? Different steering systems. Also how many miles on the clock?
