How to? Water Pump removal 97 3.9L V6
Old Nov 17, 2006 | 01:39 AM
CyrusX's Avatar
CyrusX
Default How to? Water Pump removal 97 3.9L V6
I need to replace my water pump but I'm not sure the removal direction of the central nut between the fan clutch and water pump pulley. I have the fan clutch wrench but the nut's tight either way you go. It's a 97 and has probably never been removed. Please Help.
Old Nov 17, 2006 | 01:52 AM
dodgerules86's Avatar
dodgerules86
Default RE: How to? Water Pump removal 97 3.9L V6
Welcome to the forum.
I would imagine that they wouldn't be very easy to break loose, especially if its been a while/its never been changed out.
[IMG]local://upfiles/948/0D4CA96562A44587BC1C274C1C18306E.gif[/IMG]
Also, FYI, you should post in the Gen 2 Dakota board. Just a friendly reminder.
Old Nov 17, 2006 | 08:52 AM
CyrusX's Avatar
CyrusX
Thanks alot
Old Nov 17, 2006 | 09:34 PM
dodgedakotacrazy's Avatar
dodgedakotacrazy
which way does the fan spin?/ can't remember but it will be the oppisite way because when it spins they want it to tighten it.
