starter problems
Old Dec 3, 2006 | 12:42 PM
nbass's Avatar
nbass
Default starter problems
What would cause the starter to keep disengaging after a few cranks? It will eventually stay engaged long enought to start, but only after about 10/15 tries.
'94 3.9L
Old Dec 3, 2006 | 02:47 PM
jonnymagnum's Avatar
jonnymagnum
Default RE: starter problems
it sounds like your starter is about to crap out.
________
korean girl Cams
Old Dec 4, 2006 | 01:24 PM
rapaxis's Avatar
rapaxis
If all the teeth are good then it sounds like it is the relay on the starter itself.
Old Dec 4, 2006 | 09:49 PM
BOOMER_87's Avatar
BOOMER_87
the starter probably has a bad bendix this is a problem I am all too familliar with jst pull it and have it tested and repaired or just replace it the relay or solenoid si mostly a work or not item if you want to know for sure just jump the posts on the starter...
Old Dec 5, 2006 | 01:05 AM
Mr_Shorty's Avatar
Mr_Shorty
If you pull the starter and are cheap.... you can pull the solenoid apart and clean up the brass contacts with some sand paper and it will work like brand new. I did my uncles 318 starter that way 4 years ago and it is still working perfectly.
Later Daze,
Shorty
Old Dec 7, 2006 | 03:20 AM
gb6491's Avatar
gb6491
I agree that it's probably the starter going bad, but here are some other things to check:
1.Check your battery, connections and cables as well; this operation takes quite a bit of juice.
2.Your starter could be out of alignment; check to see if there is any reason why it may tilt or move causing the teeth to not mesh properly.
ORIGINAL: Mr_Shorty
Later Daze,
Shorty
If you decide to tear the starter down, here are a couple of helpful pages
http://www.nasyard.com/infoA.html?1134889606312
http://www.nasyard.com/click/Main_Li...ml?refid=store
Regards,
Greg
