will the 97 - 00 wheels fit my 92 dakota 4x4
Old Dec 4, 2006 | 04:24 AM
winter ride's Avatar
winter ride
Default will the 97 - 00 wheels fit my 92 dakota 4x4
i should of asked befor i bought them but will they, they are the ones that kind of look like a 5 star wheel thanks
Old Dec 4, 2006 | 04:26 AM
charger_340's Avatar
charger_340
Default RE: will the 97 - 00 wheels fit my 92 dakota 4x4
if they're 6 lug, yea they should fit
Old Dec 4, 2006 | 04:32 AM
dodgerules86's Avatar
dodgerules86
No.
After a problem I had in May, I had 2 installed on the front and immidiatly I could hear them rub. (I think they were rubbing against a bolt, but I don't remember). So back to the originals I went.
Old Dec 4, 2006 | 05:04 AM
winter ride
well that sucks,, i wonder which ones you tried?? as it looks like there was 3 dif wheels on them. i knew the cooler ones didn't fit , but these the off set looked def.
Old Dec 4, 2006 | 05:35 AM
dodgerules86
Shown below are the ones that were put on.
[IMG]local://upfiles/948/15F672C9D8034AC3B112A734A7F343DD.jpg[/IMG]
Old Dec 4, 2006 | 05:43 AM
winter ride
ok the ones i got don't look like that maybe the ones i got might work, those look like the 15x8's , these are 15x7
Old Dec 4, 2006 | 11:37 PM
injmopar's Avatar
injmopar
It's too bad that someone at dodge just could not use the standard 6 bolt pattern that everyone has used for years.
Old Dec 5, 2006 | 02:16 AM
dodgedakotacrazy's Avatar
dodgedakotacrazy
all 91-2002 dakotas have 6X4.5 bolt pattern. the rub you was hearing dodgerules was on 2 things the bolt for the brake line going into the caliper (grind it down) and the tierod ground it down to no rub works great. also the Dodge viper rims will fit on the dakotas
