inside Fuel tank
Old Dec 24, 2006 | 05:06 AM
Calif89dakota's Avatar
Calif89dakota
Default inside Fuel tank
I pulled the gas tank out of my 89 dakota to change the fuel pump. I didnt know what to expect when i opened it up and upon pulling it out it managed to come apart in a few place's [&:] , would like to know if a diagram or pics of the inner workings of the tank are available?
Thank You
Old Dec 24, 2006 | 07:26 AM
jesoma's Avatar
jesoma
Default RE: inside Fuel tank
what pieces came apart?
Old Dec 24, 2006 | 07:05 PM
injmopar's Avatar
injmopar
If you are buying your parts from the dealer it probily doesn't matter.They will probily only sell you a complete assenbly.
Old Dec 25, 2006 | 06:32 AM
Calif89dakota
the resevoir came off and a black clip it looks like thealum. line goes into the bottom of the resevoir. i am not planning to buy the whole thing just the pump and filter.
Old Dec 26, 2006 | 02:58 AM
jonnymagnum's Avatar
jonnymagnum
it should be easy enough to put back together then, aslong as you didnt break anything major. when I took my fuel pump out I broke the clamp that holds it on, so I just put acouple gear clamps attatched together to hold it on.
Old Dec 26, 2006 | 05:36 PM
gb6491's Avatar
gb6491
Here's what the 89 service manual has: http://gbrannon.bizhat.com/pump.htm
Regards,
Greg
Old Dec 29, 2006 | 01:30 AM
Calif89dakota
Thank You for all your help . The dodge is back on the road and runnin good .
Its amazing what make's my day sometimes.
Sincerly
Ken
