Fault Code 32 - EGR Related
Old Dec 26, 2006 | 10:02 PM
daniel981's Avatar
daniel981
Default Fault Code 32 - EGR Related
I have a '94 5.2L and the check engine light keeps coming on. I pulled the code and it came us as 32, which when I looked it up is EGR Valve related. Anyone else have this issue before? I priced a EGR valve out, and its $100. Not to bad, but can I just clean or fix the one on the truck? Or is there something else that could be causing the light? Thanks
Old Dec 27, 2006 | 08:02 AM
BAnders's Avatar
BAnders
Default RE: Fault Code 32 - EGR Related
you could probably take it off and clean it and check the O2 sensor[/align]
Old Jan 4, 2007 | 02:23 AM
thekeeling's Avatar
thekeeling
Try pricing it through Chrylser, they're usually cheaper than after-market. They also usually come with the EGR solenoid as well. Does the code come back on immediately? If it does, it's probably the solenoid shorting.
Old Jan 14, 2007 | 01:17 AM
daniel981's Avatar
daniel981
Well, I ended up replacing the EGR Valve, and that fixed the problem. Got the EGR Valve for $75 at autozone.
