Power Steering
Follow up to my post. Sucked out the fluid with a turkey baster and put new. No help turnes to the left fine but hard to turn to the right when going slow. If crusing down the hwy works o.k.
I doubt your rack and pinion would cause that. I replaced my rack and then my pump went. so I put a used pump on it off of one of my other vehicles, it will sometimes get stiff when turning right. but if I rev it up abit it will be fine.
my pump was a pita to do since I just got done replacing the rack and found out the pump was blown too.[:@]also I had to switch pullies since the dak needs the one with the holes in it. it took me about 2 hours to do the pump cause of that stupid pully. either then that it was pretty easy.
ya I used one but mine was on there tight. and the threads were all rusted too. so I had to tap in new threads on the shaftof the pump.[:@]
Trending Topics
Changed the pump no help. I had let someone use my truck and the turning radius on the 90 is not much and I think they were turning right and peged it hard to make the turn and something happened in the rack & Pinion. Not sure what to do now!!!!!!!!!!!!!! I am going to try some snake oil that Lucas has.
