rear veiw mirror mount
Old Jan 2, 2007 | 12:11 PM
fishlessman's Avatar
fishlessman
Default rear veiw mirror mount
is there a way to easily remove the mount thats glued to the windshield without breaking the glass, i need to move the mirror up a few inches from where it now sits.
Old Jan 2, 2007 | 03:08 PM
jonnymagnum's Avatar
jonnymagnum
Default RE: rear veiw mirror mount
that lil metal piece is on there pretty good. you could try some paint thinner or something that will remove glue. then just take a putty knife and try and pry up on it. then take a razer blade and take off all the ramaining glue. and you'll have to buy a specail epoxy just for windows. you can buy it almost anywhere. when mine fell off I just went to a napa dealer and they had it there.
Old Jan 3, 2007 | 04:09 PM
nightwatch's Avatar
nightwatch
They do make a remover for that type of glue. I had to remove a glob of it before putting a new mirror on once. The stuff softened it right up and it came off with a scraper easily. I don't remember what it was called, but am pretty sure I got it at O'Reilly's. Seems like the sovent was acetone. A glass shop should have it if the parts stores don't.
Old Jan 3, 2007 | 05:23 PM
fishlessman
ill give the solvents a try, i have acetone, xylol,laquer thinner, and maybe some other stuff. maybe some dental floss soaked in it and worked under it might work. only place i found some instructions on the web, and the first person to comment on it said he pulled a chunk of glass off the window.
