tires
got a 91 extended cab with 21575r15 on stk. rims with rear abs.
wanted to go to bfg k/o @ 235 75r 15 & was told they'll rub in hard turn
plus in new jersey there's a law about running same size tires all around ???
even though i only got rear abs .
any input ???
thanks
any input ???
thanks
I had 235/75/15 on mine a while ago. they were on the rims when I bought them. but I had some minor rubbing when turning. but it was nothing more then a hammer could fix.
I ended up taking them off because the got bald and blew a belt.
I believe it comes down to if your truck is 4WD or 2WD, at least that what it appears when looking at the 1990 service manual.
For 2WD trucks, it lists 195, 205, and 215 /75R15s, while for 4WD trucks it lists 195, and 235 /75R15s.
My 1996 4WD came with 235/75R15s from the factory, and, of course, no rubs.
I'm having to replace my tires for that same reason. I bought a 92 2wd club cab with 235's. They are rubbing, so I'm switching to 215, either the Goodrich Radial Long Trail T/A or Uniroyal Laredo All Season AWP. They're good looking tires. Goodrich also has the All Terrain, but they're too much for what I need. From all of the reading I've done on this and everyone I've talked to, 215's are as wide as I can go without modifying anything. 4wd's can take the 235's though.
