light ring around ignition switch?
Old Feb 12, 2007 | 03:59 AM
bradford14's Avatar
bradford14
Default RE: light ring around ignition switch?
which one did u replace?
Old Feb 12, 2007 | 03:18 PM
Colorado05's Avatar
Colorado05
Under the hood INT. LAMP is a relay but there is a 5 amp fuse that is called ign something that in the owners manual says it controls the courtesy lamps. It was blown and I replaced it and it all works now. I will attempt to attach a picture, where my finger is pointing is the one I replaced.
Old Feb 12, 2007 | 06:37 PM
bradford14's Avatar
bradford14
cool thanks!
Old Mar 20, 2007 | 03:57 AM
ddt1974's Avatar
ddt1974
hrmmm my key light ring don't work either
allother interior lights work
anyone actually try and replace the bulb?
looks like it's gonna be a serious pain to get too
if I actually get to it, I'll let u know
I wanna put red in
Dennis
Old Apr 20, 2007 | 08:08 PM
azkitch's Avatar
azkitch
I'm typing around my ignition switch now, cuz my ign.sys.fuse underhood blows. Not like sux, but like burns out. Anyway, the Ig sw. is held in by 3 tamperproof torx 20 screws, the 2 connectors pop off, and it's in your hand. Assuming you've taken off the shroud top & bottom, which also entails removing the tilt handle IA.(if applicable)...Clear ring pops off, white ring comes with it, clear bulb in a green plastic lens. I don't think any color changes goin' on. Maybe can remove lens, dunno if #37 bulb avail in color. But anyway, there ya go.
Old Jul 24, 2014 | 04:35 PM
Laidbackcruz's Avatar
Laidbackcruz
Default Question?
Originally Posted by dodgerules86
Mine works.
It gets its power from the time delay relay (located on the fuse block), and is energized anytime: one of the doors are opened, or anytime the headlamp switch is put in the "dome light on" position (**** turned all the way to the left).
The courtesy light (located in the passenger side foot area) is also provided power from the time delay relay under the same circumstances.
The ignition light on my 95 Dakota always stays on I think it's draining my battery and I've noticed other lights interior don't work
Old Jul 25, 2014 | 08:22 AM
92DakotaClub's Avatar
92DakotaClub
HOLY THREAD RESURRECTION BATMAN!
Sounds like you got a grounding issue or a short somewhere tho . hell it is a chrysler product its gonna be electrical! LOL
