92 fuel problems
Old Feb 4, 2007 | 11:39 PM
djscott's Avatar
djscott
Default 92 fuel problems
I have a 92 Dakota v8 4x4 with 180,000 miles. It ran fine and all of a sudden it acts as if its out of fuel. If I let it set for 1/2 hr or so it will start and run for about 5 min then acts up again. I replaced the clogged fuel filter and thought I had it as I drove it hard for a mile or so and all seemed good. Several hrs later it starts fine and stalls after 10 min of idleing. I took of the fuel line and noted when I turn the key on I got a squirt of fuel, when I started the engine I had plenty of fuel pressure ( had a pin hole in the linefrom chaning filter that shot 2 ft ) Does this sound like fuel pump issue or a relay. When it dos'nt start I can use starting fluid and it will pop right off. I really dont want to change the fuel pump If I dont need to as its costly and 5 degrees here right now..any help out there? Thanks
Old Feb 5, 2007 | 12:05 AM
BAnders's Avatar
BAnders
Default RE: 92 fuel problems
buy a tank of supreme and add a can of B-12 chem tool to the tank, also a tune up wouldnt hurt either. get an additional can of b-12 and add that to the oil, run for 5 min and drain, that should help out[/align]
Old Feb 5, 2007 | 07:32 AM
djscott's Avatar
djscott
When its in the "no starting mood" it acts like I have no fuel. I let it set for a bit and it will start and run for a bit but then quites.
Old Feb 5, 2007 | 08:58 PM
gb6491's Avatar
gb6491
This thread might be worth a look: https://dodgeforum.com/m_676574/tm.htm
Regards,
Greg
Old Feb 8, 2007 | 12:20 AM
djscott's Avatar
djscott
Got it. It was the fuel pump. It would get hot and just quit when it cooled off it would work untill it warmed up.
