Need help.
Old Mar 25, 2007 | 02:57 AM
95kota's Avatar
95kota
Default Need help.
I have a 95 Dakota witha mildly built 5.2. Here lately it has begun to backfire and seems to be low on power. It feels as though it is starving for fuel. I checked the coil amd have no problem there. My fuel gauge works whenever it gets a notion to. Could it be a short in the fuel pump? Has anyone had this happen to them. I found that the EGR catalyst sensor had a hole burned in it and replaced it with the EGR but it didn't solve the problem. I need some expert advise.
Old Mar 26, 2007 | 05:45 PM
Casper50's Avatar
Casper50
Default RE: Need help.
Did you check the timing?
Old Mar 29, 2007 | 01:19 AM
95kota's Avatar
95kota
Timing is fine. I thought the same thing at first with the different cam but timing is okay. I have read ALOT of fuel pump problems in this forum and have just about decided to just change mine.
Old Apr 2, 2007 | 01:47 AM
95kota's Avatar
95kota
Problem seems to be solved. New fuel pump. Old fuel pump was catching on rails. This site doesn't seem to have anyone willing to help in it. I guess next time I will have to go to another site.
