2 oil cap?? which one to fill?
Old Jul 13, 2010 | 09:27 PM
modulo30's Avatar
modulo30
Talking 2 oil cap?? which one to fill?
Hi, i got a new 4x4 Dodge Dakota 1992 5.2 318 magnum efi.
I was about to made my oil change,and i figured out that a got 2 place to put oil on, 2 oil cap???
I very newbie, but i want to make sure i dont damage my 6truck, can somebody tell me which one its the correct one..
here the picture right one
Uploaded with ImageShack.us
and the left one
thank
Old Jul 13, 2010 | 09:37 PM
95_318SLT's Avatar
95_318SLT
Welcome to DodgeForum!
Hmm, my truck only has one on the left bank... but since you have two, pick one. Or pour half the oil in one and the other half in the other. You really can't mess it up!
Old Jul 13, 2010 | 11:31 PM
Crazy4x4RT's Avatar
Crazy4x4RT
Ya my 93 5.2 had 2 as well. It doesn't matter which you pour it into.
Old Jul 13, 2010 | 11:37 PM
modulo30's Avatar
modulo30
Default RE
Hi, ok thank a lot, i try it tommorow i let yu know
Old Jul 14, 2010 | 08:11 AM
tmacdakota's Avatar
tmacdakota
Yep, don't matter...they both go the same place. I wondered about this and decided they engineered it with 2 filler caps to make service easier...between the 2, one has got to provide easier access depending on whether you're a rightie or leftie.
Old Jul 14, 2010 | 01:31 PM
LO 619's Avatar
LO 619
I'm pretty sure someone did that, I doubt it came that way from the factory.
Old Jul 14, 2010 | 02:37 PM
Crazy4x4RT's Avatar
Crazy4x4RT
Yes they did come stock! Most likely it is due to them using the exact same valve cover on both sides, which saves time/money by not having to mass produce a 2nd one. But in the long run it takes more money to produce more caps. 2 per engine vs 1 per engine, so that is why they probably just went back to 1 per engine.
I wish I keeped the passenger side one from my 5.2 to put on the 5.9. The driver side has the heater hose in the way.
If I can find a pic my my 93 manual I will post it up.
Old Jul 14, 2010 | 02:51 PM
issakar's Avatar
issakar
I went to the boneyard today and was looking for an oil cap. a lot of them had the 2 cap design.
Old Jul 14, 2010 | 05:43 PM
tmacdakota's Avatar
tmacdakota
Mine is stock with two caps, one on each bank.
Old Jul 15, 2010 | 03:24 PM
modulo30's Avatar
modulo30
Default re
Hi, well i think its true, some model come with 2 cap..
btw my oil change was 50/50 on each side and everything is ok , so thank a lot to you guys!
