Auxiliary/transfer fuel tank install
Old Jun 12, 2012 | 09:43 PM
AZ 360 Dakota's Avatar
AZ 360 Dakota
Default Auxiliary/transfer fuel tank install
I didn't like the range of my 22 gallon gas tank. I had a spare '98 Caravan gas tank and fuel pump. I was going to use that but it's only 20 gallons, flat and wide. So instead I got a 26 gallon one out of a '99 Dodge Ram that's taller and takes up less bed space. I really wanted a 35 gallon out of a Ram but that was way too long and wouldn't work.
The metal I used for the fuel filler neck support. Look familiar?
This is a transfer tank only. It pumps out of the auxiliary tank into the main tank. I tapped into the factory fuel filler neck vent hose. I also spliced the vent from the rollover valve into the factory line so the vapors get collected into the charcoal canister instead of the bed of the truck. I used brass for durability. I don't trust plastic.
I installed a toggle switch to switch between the fuel level in the auxiliary tank and the main tank. I also installed a clear fuel filter to watch fuel flow so I'll know the tank is truly empty.
Main before pumping:
Auxiliary before pumping:
Main after pumping:
Auxiliary after pumping:
I had an normal lighted toggle switch to turn the fuel pump on. Well on my last trip I accidentally hit it. So I changed to an F-15 missile launcher type switch.
I’ll know this one is on.
I got some fuel tank straps from a Dodge van. They were longer so I had more room to customize them.
Bottom one is original length.
I folded it over like the factory for durability.
A.J.
Old Jun 13, 2012 | 01:58 AM
Crazy4x4RT's Avatar
Crazy4x4RT
That is a cool install. I'll throw it in the FAQ2 in the DIY section.
Maybe build a quick sheet metal box to cover it up so when hauling stuff in the bed it doesn't have a chance to possibly puncture it.
Old Jun 13, 2012 | 10:15 AM
volaredon's Avatar
volaredon
you didnt like the range of a 22; I had a 15 in my 94 reg cab and its range really sucked. I changed to a 22. I wish I could add the 15 back in as an aux. tank but at the same time both my trucks are shortbeds (one is a CC) and I dont wanna lose that much bed space to do so.
Old Jun 13, 2012 | 08:57 PM
AZ 360 Dakota
I plan on some type of protection for it. I threw this together as fast as I could for a recent trip to California. With this tank I only had to buy about 10 gallons in CA instead of 36 gallons. I'm going to paint the exposed metal and make it look better when I have extra time.
I get about 230 miles to a 22 gallon tank combo of city and highway (mostly city). I'm heavy on the throttle.
I didn't want to lose bed space either but there is no room under the bed unless you're really creative in relocating the exhaust. I don't use the max capacity of my bed so I'm not losing a whole lot. And at some point I'm going to make the auxiliary tank removable just in case. I still don't know how the race track is going to react to it.
A.J.
Old Jun 18, 2012 | 09:48 PM
AZ 360 Dakota
I took some more detailed pictures and also made a few modifications/improvements.
Here's the top of my auxiliary fuel tank sending unit. I used an old sending unit from my '94 Dakota with a few modifications. First the output/fuel filter was removed for the '92-'93 output/return fitting. Then the return was capped with a cap from another sender I got. My thinking is if I'm on the road and my fuel pump goes out, I can swap in the aux fuel pump to get home once I cut a hole in my bed for fuel pump access. The fuel filler vent was plugged with an extra electrical plug I had. I pulled the wires out and installed it in the rubber grommet where the fuel filler port lived. I did that because the tank came with the fuel filler vent. Then the rollover valve was replaced with a black cap that I got off of a Ram van fuel sender since the tank came with a roll over valve/vent.
I put the clear fuel filter up higher so I can see it in the rear view mirror. I have the two tanks on a toggle switch to see the level in both but we all know that empty isn't always empty. So now I can see the air bubbles when the pump starts sucking air.
I opened up an already existing hole to run the fuel, vent, and electric.
I painted the fuel filler neck and filler tube since the manufacturer never intended anyone to see them.
A.J.
Old Jun 30, 2012 | 10:10 AM
Remark's Avatar
Remark
I like it.
Fantastic job.
Old Jun 30, 2012 | 06:12 PM
93MissDakota's Avatar
93MissDakota
for real, very nice
