1994 Dodge Dakota Scotty--Any Issues?
Old Sep 29, 2013 | 09:13 PM
Ashevillian's Avatar
Ashevillian
Default 1994 Dodge Dakota Scotty--Any Issues?
Hi,
I'm looking at a 1994 Dodge Dakota Scotty RV with the 318 V8 engine and an automatic transmission. It has 55,000 miles. I'm wondering if there are any issues I should know about with this truck/driveline? I saw a this one: http://www.haylettautoandrv.com/rv/c.../other+scotty+
Which is a 1992 with the same engine and I assume same transmission and it needed to be replaced at 41,000 miles...is this a common issue or a one off event?
Thanks
Old Sep 30, 2013 | 12:30 AM
RockGuardedDak's Avatar
RockGuardedDak
Originally Posted by Ashevillian
Hi,
Thanks
I've never seen anything like this before. I'm assuming its a custom rv, and has inspired me for when the old lady gets a new vehicle. However, I would assume that due to the weight that the transmission is always pulling, I'm willing to bet this setup would eat transmissions. That's a lot of weight to be pulling all the time. Especially if your pulling a boat behind you as well. That's too much weight for these automatic transmissions. I don't remember their limit, but maybe someone who knows will chime in.
If you bought it, it would be in your best interest to swap that automatic for a manual transmission
Old Sep 30, 2013 | 12:35 AM
Cooreman's Avatar
Cooreman
That thing is wicked!
Old Sep 30, 2013 | 01:07 AM
Brian in Tucson's Avatar
Brian in Tucson
Bet the quoted fuel mileage is a bit optimistic.
Old Sep 30, 2013 | 12:11 PM
Cooreman's Avatar
Cooreman
That's when the interior is gutted aha, I wonder if it's a stock dakota drivetrain or things are slightly beafed up. Although this now means if some one gets bored enough we might see a double axled rear end In a dakota
Old Sep 30, 2013 | 12:58 PM
Brian in Tucson
The rear axle is just a tag axle--for taking up rear weight--all that body work plus a gas tank full of fuel is heavy.
I'll bet it ain't a 3:55 rear end. Ya know, if they could do it all with a Toyota Hilux (with a 4 cyl. engine) it shouldn't be too much of a problem doing it to a Dakota chassis.
Old Sep 30, 2013 | 01:22 PM
RockGuardedDak
Adding in a USEABLE 2nd axle would be how I would do it if I did do it. I'd want that 2nd axle to have drive as well as displace the weight. But that's a lot of custom work finding gears like that that would bolt into that carrier, either that or move the stock carrier to the very back, and find a different carrier that has input and output gears. By carrier, I mean the diff carrier.
I'm willing to bet that if they blew the tranny that soon, it's likely the stock drivetrain. Maybe 3.92's instead of 3.55's but that's it. Still, very intriguing for a project. I'd be interested in building one out of my old dak in the near future
