Dodge dakota engine swap
Other issue is motor mounts....the magnum has both sets...front and mid. The LA only has the one set. I don't think it'll be a direct drop in.
Here's a decent link for what's interchangeable and what's not.
http://www.magnumswap.com/using-la-parts-on-a-magnum/
For what you have to do, you might as well swap in something besides a 318 ... this is like "I have a Chevy 350, wanna swap in an Olds 350, does it drop in?"
Robertmee has one of the sources you can use; Schumacher ( http://www.engine-swaps.com/Pages/Pr....96Dakota.html ) has some of the parts you'll need; but you'll also have to either get the heads cross drilled to swap to fuel injection, or convert to carbed.
You're lucky at that - a year or two earlier, and it might have been an A block 318 with the polyspherical heads, not the LA block 318!
Might do better selling the old 318, using it to purchased a used 5.2 Magnum to replace the "no good" 5.2 you have, and getting the new 5.2 rebuilt.
You can also swap in a 5.9 Magnum (360); that will give a nice kick.
Hughes Engines ( www.hughesengines.com ) is one place you can find a stroker kit; take that "no good" 5.2 to 390cid, REALLY wake the truck up *grins*
(And if you absolutely positively MUST go backwards; find a 340.)
RwP
RwP
